ok ευχαριστώ για τις απαντήσεις , όπως λέτε το ρελέ είναι 10Α ενώ θα χρειαστεί τουλάχιστον 20Α και λέω να πάρω αυτό που βάζω στη νέα φωτογραφία(θέλει και ένα συνεχές 12v) και νομίζω πως αυτό έχει
και είσοδο για τον αισθητήρα....τι λέτε????
παρακάτω δίνω Product Details:The module consists of a microprocessor controlled delay time, timing precision (under a variety of ambient temperature error is less than 2%), and can be customized on the basis of this hardware you need delay function or other functions.
Product Details:
The trigger is turned on, the delay off. Configuration: trigger termination button, S6 disconnected.
After the trigger delay, after the arrival time on. Configuration: Trigger end button, S6 connection.
Module Working voltageC 12V
The length of the delay set by the time required to use a soldering iron values ??in the table were short set.
When all the time is short contacts are all turned off, the trigger is a bistable, that trigger what pull the trigger and then look off.
The control signal is triggered, signal cancellation or delay will not affect the holding after the trigger.
Again triggered during the delay, the re-timing
If the key short-circuited, then each will power the control board generates a trigger delay action, equivalent to pressing a trigger button.
The module circuit board size: 82mm x 35mm
The module with reverse power protection.
This module with opto-isolated, suitable for signal drive, if desired button triggers, give a 12V voltage to optocoupler.
1x Delay Timing Turn on / off 30A Relay Module Switch Timer
(The C2 capacitance is not contain)
