Datasheet or service manual? Please discribe the problem of the amplifier.
Όχι άλλους μΕ....PICάραμε!!!!
Hello,
I would like repair manual.
My actual problems are:
- scratching on left after to clean potentiometer with cleaner=> thinking to dried welding because it is doing it without touching to any pots.
- I cleaned pots because I have residual sound in left output even when volume is turned to 0.
Thanks in advance![]()
What inscriptions do th pots have? try teslanol kontakt for scratching
Welcome our collegue from France! I think that this will be your lucky forum..I have the service manual for Denon SA-30. Please send me a private message with your e-mail address so that I can send it to you. Best regards..
